I have a 60 gallon compressor in my garage. From the compressor the line goes through a dryer, then a regulator. After the the regulator there is a T one leg of which is a coupler for a hose. The other leg of the T goes to a reel that I have about 12 feet away. Between the compressor and that hose reel there is a length of hose about 12 feet long. I came home the other night and the hose from the compressor to the hose reel was drastically expanded and about to pull off the hose barbs and/or explode. That would be bad.
Since the regulator has a check valve it prevents extra line pressure from returning to the tank. My guess in what happened is that the extra heat in the garage caused the air in the line to expand.
My solution to the problem is to put in another T after the regulator and in that T put in a pop off valve like you have in the compressor tank itself. I ordered a 150 psi valve and put it all together tonight. I had been concerned about the valve not closing before the compressor kicked back in around 90 psi. I was correct.
If I leave the set up as is, if the pop off in the line ever goes the setup is going to continue to spew air and the compressor run until I get home and manually reset the valve.
Ideally I would like to figure out a valve like this one that closes sooner.
Here are my questions:
1. Is there a chart anywhere online that would tell me the pressures at which a pop off closes?
2. Any idea the pressure at which a normal air line would start to expand like it did?
Ideally I need to either:
a. find a valve that opens at less than the answer to question 2 and shuts before 90 psi
or
b. reengineer another solution.
I do realize that I could just shut the valve off at the tank each time I am done using the compressor but I really prefer to have the air line ready to plug in a tool and go.
Any thoughts?
or
Any thoughts?
