I picked up a 55 gallon single stage Devilbiss compressor about a month ago. The price was definitely right. The guy had moved and his new garage didn't have 220v.
Anyeay I got the circuit run to the garage and got everything wired tonight. It runs pretty well. Definitely needs anchored to the floor yet as it walks a bit. It ran from completely empty up to 120psi. It probably took about 6 or 7 minutes. Afterwards the tank itself was actually warm. Is that normal? I know the compressor head should be hot but didn't know if the heat should be so great as to cause the tank to warm a bit.
