Hannah's clutch and pulley.
Steve in VA
So, the shop finished replacing the missing chunk from the belt pulley. I can only imagine that it must have been dropped at some point. I believe I've figured out the clutch mechanism. It is crudely adjusted. A few other priorities have gotten in the way but, with luck, I'll get it reinstalled later today.
(quoted from post at 15:26:58 11/05/22) They really did a great job didn't they?
I'm not seeing a photo of the actual repaired broken pivot point of which you have previously posted a photo in it's broken state.
They've done a few repairs so maybe we're
talking different phases of this project.
In this final job they replaced the
missing chunk from the pulley face.
They have also repaired the mixer and made
a wrench to remove the axle nuts.
Maybe we're talking about this farm fix. I left it as found since it seems to work fine and is part of her history.
Likewise I saved this wonderful repair of the fuel pump. Someone spent time fitting and riveting these plates.
Yes, for some reason I thought you were having the hay-wired clutch toggle pivot point repaired.
Didn't realize you would leave that ''as found''.
As to the fuel pump, SOMEWHERE I have an IH pump with a very similar repair.
Must have been common for them to break.
Perhaps they broke when they were stuck or frozen and someone cranked the engine?
