Walboro carburetor.
Gene Davis (Ga.)
Hi. I am restoring a old Mott push type 21 cut flail mower with a Clinton engine and have a problem with the carburetor body.After cleaning it and as i was reassembling it the threads stripped out of the body where the main nozzle goes, They were very thin and when I tightened it they pulled out before they tightened. Tried building up with J B weld but that did not hold either. Does anybody have a Walboro LMV, LME or LMG carburetor they would sell.I could get by with just the main body and use my inside parts if necessary. Gene Davis Tennille, Ga.
Email is: [email protected] xxx ---remove the three x's to send.
letters and numbers on the carburetor are: LMG and on a raised boss above this are these numbers: 115. Thanks for looking. gene Davis
Gene, years ago I repaired the threads on a Cub main jet hole in the carb.
They are very fine threads also.
Old auto parts store had an epoxy thread repair kit that worked very well.
That Cub is still going.
It has been too long ago for me to remember the name of the stuff I used.
