I have a Wisconsin single cylinder motor that is used on an ingersoll Rand packmaster compactor. I need to remove the centrifugal clutch off the shaft.
Outside pulley was held on with a C ring and it pulled off. Inner clutch does not have a set screw that I can find. The backing plate is too thin to use a 3 jaw puller on.
I can't get a bearing puller behind it enough to grab.
Any thoughts on what might work to pull it off?[/img:2a84e7e5fd]
