Removing a centrifugal clutch
Catchb52
New User
I have a Wisconsin single cylinder motor that is used on an ingersoll Rand packmaster compactor. I need to remove the centrifugal clutch off the shaft.
Outside pulley was held on with a C ring and it pulled off. Inner clutch does not have a set screw that I can find. The backing plate is too thin to use a 3 jaw puller on.
I can't get a bearing puller behind it enough to grab.
Any thoughts on what might work to pull it off?[/img:2a84e7e5fd]
(quoted from post at 18:52:04 07/20/20) Is it on a taper? Get a pry behind it & hit the shaft with a brass hammer.
Not that I can tell. Looks like a regular shalt. There is a my on it, so I am assuming it was pressed on. I have never seen one on a regular shalt without a set screw.
I am going to build a plate I can get behind the clutch shaft and then heat the shaft.
K will let the group know how it works.
