Wisconsin AENLD
I have a Wisconsin AENLD serial # 5131208 that mounts on a Kut Kwick brush cutter model EDV920.
The cutter is in good shape but the engine is pretty bad and seized.
Does anyone know where I could find a replacement engine?
Is there a comparable engine that might fit?
"The AENL was is a 9.2 HP @ 3600 RPM engine. The "D" suffix indicates these have the valve rotator added to the exhaust valve."
Predator engines (Honda clones) from Harbor freight seem to have a reasonably good reputation, they jump from 8 HP to 13 HP, the 13 HP is under $400. Even has electric start, along with the recoil start.
Might work for you?
I just purchased a Wisconsin AENL with a clutch assembly to replace my AENLD mounted on a Kut Kwick brush cutter. Looks like it will fit fine. I plan on selling the clutch assembly as it will not be needed. Any idea of the value? Case was full of oil and everything looks like new inside.
