Gary in Indy
I have a 1967 MVH4D engine on a OMC skid steer. The way I understand it the engine rotates clockwise when viewed from the flywheel side. The starter (maybe a Prestolite 46-911, MBG 4141?) looks like it has been with the engine for awhile but wouldn't turn, so I removed it and cleaned it. It turns fine now but the bendix (inertia) won't kick out. The starter turns clockwise when viewed form the snout/gear side.
The Questions..... Shouldn't the starter turn counterclockwise? Counterclockwise starter would equal clockwise engine, Correct?
Is this the correct starter for the engine or should it be one with a bendix on the outside like the second one below? Does it matter?
Would my starter (no tags) be 6v or 12v?
Both starters below say they fit the VH4D, is (military) MVH4D Different?
What the starter on the engine looks like. Note it says counterclockwise with 10 teeth
https://www.amazon.com/STARTER-TELEDYNE-WISCONSIN-ENGINES-MBG4141/dp/B01MQT7WFP
Maybe it should be? Note it says counterwise with 10 teeth
https://www.amazon.com/STARTER-WISCONSIN-ENGINE-10455339-10455354/dp/B009SRB8QQ
Thanks for any help
Thanks for any help
