Do I need to remove the oil pan to remove some sludge or if I just put in some type of cleaner like diesel or kerosene leave it sit an drain would that help? The motor dose run but when I drained the oil I can feel some sludge around the plug. I just bought it an never owned one before. Thanks
Should not be a big job and if it's bad as you say would not hurt. Also you can get at the oil pump to clean. Fun little engine I have one.
I just got the motor running I am getting puffs of blue smoke what could that be? Carbarater or rings? Other then that it ran ok.
(quoted from post at 16:13:10 05/06/19) I just got the motor running I am getting puffs of blue smoke what could that be? Carbarater or rings? Other then that it ran ok.
Until you've warmed it up, and RUN it and WORKED it a little exhaust smoke or a weak compression test is MEANINGLESS.
