Wisconsin vH4D no spark
Not sure what else it could be. I have a Wisconsin VH4D in my old
hydra cat loader with no spark. I have replaced the points, wires, coil
but still nothing. What could I be missing? Thanks.
(quoted from post at 19:25:59 04/10/19) Not sure what else it could be. I have a Wisconsin VH4D in my old
If the engine has a high-temp cutoff switch mounted on one of the head bolts, a wire from the switch goes to the breaker points side of the coil, and if the switch shorts (common) it will be like the breaker points never open. Something to check for.
Also, have you verified the distributor turns, the drive gears have been known to shear.
