This message is a reply to an archived post by Anthony76 on March 14, 2018 at 21:35:14.
The original subject was "John Deere Model E".
Anthony have you got your Generator working? (Low tension mag). If you have not sent it off to be fixed. Remove the bearing cap. There is a carbon brush in the cap that rides on the Armature. Clean them both with rubbing alcohol. Put the end cap back on. Unscrew the output tower. It also has a carbon brush init. Clean it with alcohol and get Qtips and put alcohol on them them stick it down on the copper ring inside the hole you opened up. Turn the engine over real slow. Keep changing Qtips and alcohol until the Qtip comes out clean. Put the output tower back in. And attach the wire. A solid copper wire works better than a stranded wire. Hold the wire to the hopper or block which has a good clean spot. As you turn the engine over rake the wire on the clean spot on the engine and check for spark. Or you can test it with an VOA meter, set to AC volts 0-12 volts or closest setting on meter that will show you 5 to 9 volts on the meter to check for output of the low tension mag. It is simple. If the bushing in the low tension mag are worn and the armature is dragging inside you will not get any voltage. Replace the end cap .
