Company Logo Shop Now
TractorLinks.com
Stationary Engines Discussion Forum
Air compressor engine 6 cylinder
golfcartman
11-03-2018 19:35:27
I have a IR 3 R 36 radial air compressor engine that runs on 3 cylinders and pumps air with the other 3. Does anyone on this site have and Info on these engines. Pumps 36cfm's at 80 psi. They were used on the rail road. That's about all I know. I'll post a couple pics.
third party image
third party image
ldj
03-09-2019 10:50:16
 Re: Air compressor engine 6 cylinder in reply to golfcartman, 11-03-2018 19:35:27
I can't tell for sure in the photo if all cylinders are in the same plane, or ie 1 throw in the crankshaft. I thought a radial engine had the be odd # of cylinders. They could be even # of cylinders if you had 2 rows of odd # of cylinders.
VACLee
03-10-2019 09:44:43
 Re: Air compressor engine 6 cylinder in reply to ldj, 03-09-2019 10:50:16
Would it not be basically a three cylinder engine and a three cylinder compressor? Appears that each uses every other cylinder. Lee
Saskman61
11-08-2018 05:51:05
That is a pretty neat piece of gear.
Just google the following and go to the first link. The post is old but you may be able to contact the one gentleman that has the manuals for it.
Ingersoll Rand 3-R-36 info and parts needed
golfcartman
11-08-2018 16:07:03
 Re: Air compressor engine 6 cylinder in reply to Saskman61, 11-08-2018 05:51:05
Thanks, I looked at that couple weeks ago and even sent an email to one of the guys but have not gotten any reply. I checked the oil in it and it looked good. Took the rope pulley off and put a nut on the end of the shaft and used a 1/2" drill to turn it. It cranked and ran good. Put the pulley back on and now it cranks on the first pull of the rope. It puts out lots of air. I have no idea what I will do with it.
