georgelemon
New User
I have this Hercules power unit that has a rosa masters db injection pump. I went to start it n no go. It has the electric shut off device (12 volts ) set for energized to run. Should you hear a click when you turn the key on? In other words should you hear the solenoid close pulling the governor linkage hook rotating the metering valve to open. I hear nothing. I have voltage to the retaining nut. I checked the ohms between the two contacts and it read zero. I would think there would be some resistance . Eight years ago I sent the injection pump in to rosa masters and they completely went through it. When I got it back I put in on the engine and it started right up. I ran it for twenty minutes. Then I put the unit in heated storage until now. Can I take the governor control cover off with out removing the whole pump. Any experts have any ideas? If anyone would like to call me I would love to talk about this problem. Or email me at [email protected] . My number is 608-697-8508 .after 8:30 am n before 5pm thanks guys.
