IHC La belt pullys
Andrew
I have a 1.5/2.5 and a 3/5 LA the pully lock keys are seized.. what is the best way to get the pullys off? heat them up ot good old diesel fuel?????
I have a couple of LBs and are pretty much the same as LAs. There is an allen head set screw that holds the key in place. Remove the set screw and use your favorite unsticking brew and wait a few days. Hope this helps you. Joe
