Hey guys
I have the above engine, and it looks like it's been taken apart before, and not put back together right. One of the caps to the crank has been broken, and welded..I found the timing mark on the flywheel, and it says in the directions that this is suposed to line up with the shaft, when the mag fires....well it doesn't even come close, so I'm thinking someone took the crank out and didn't put it back in the right spot.It fires at the very begining of the compression stroke..Are there any whitness marks on the gears to align so we can get this back together where it's suposed to go? Thanks Art
