Internatrional LA
Andrew
I got my LA all together and does nothing but once in a while shoot a flame out the exhaust the mag is timed to the cam gear i had all the dots lined on all the gears piston at the top stroke both valves shut 100% positive its in time vlaves are adjusted there both closed has not bad compression. its also getting fuel. i spent 2hrs turning it over tonight and gave up whats is it worth the way it is its got all new gasketsand seals, frost plug, spark plug, new rings and valves were laped. It also has very good spark.
Andrew I have the same problem, all marks lined up, in time, new rings and gaskets good compression and spark. But will not even try to start.
doc
