Throttle lever drops some when i let go on 2910 ford tra
Brad2023
When I raise the rpms on 2910 ford tractor to around 1800 rpms as soon as i let go it drops to about 1600 rpms, so when I bush hog I have to hold it in place so it doesnt bog down....How can i fix this?
If the 2910 is like other small Fords, there is a frictions disc with a spring, and a self locking nut that can be tightened on the lower end
of the throttle shaft too put more tension on the disc.
tighten #7
Thank you so much after looking at a possible diagram for my tractor i went out there and looked, its kinda dirty so i almost over looked it. I was thinking it would be a bigger disk but the one on there is still there but its getting worn down on back side. I wasnt sure about any of it but there was a nut at bottom so i tried to tighten it and sure enough it fixed the problem. Now I can run bush hog full throttle without having to hold the lever.
I tried posting a picture but it wouldnt let me
thank u i did and it worked, how was you able to add a picture to the message i tried it didnt work for me
(quoted from post at 10:45:34 11/23/23) thank u i did and it worked, how was you able to add a picture to the message i tried it didnt work for me
You cannot paste pictures into posts here. To post pictures look down the page a bit from the box where you type a reply, and you will see a bar that says ''Upload Photos/Videos''. Below that is a button that says ''Choose Files''. Click on that button to go to your device where you can search the files in your device (computer, tablet, phone) to find the picture you want post, select your picture, then click the ''Open'' button and the program will upload that picture to your post. There is a size limit of about 7 MB of pictures/video per post (not per thread). That can be one picture or the total of several pictures in a post. This is the same in Modern and Classic views. Some cell phone pictures need to be reduced before they will post. And sometimes it takes a bit for them to upload, so don't hurry the process and use the preview button to see that the picture(s) is there before hitting submit.
