Restoration & Repair Tips Board
Re: 12 v system charging system
ken44520978
11-20-2023 19:29:49
If you are using a digital volt meter you may be getting false readings when the tractor is running. If you have access to an analog voltmeter give it a try to verify interference isn't confusing the digital meter. I have seen it happen many times.
