Oliver 1655 Over/Under Input Shaft Wear
I am currently redoing an Oliver 1655 that had a cracked bell housing. Once we got everything pulled apart we noticed the input splines on the input for the over/under, as well as the clutch had wear on them. I was curiuos if anyone else has seen anything like this or if anyone had a reccomendation on replacing the shaft or leaving well enough alone? I was planning on installing a new clutch and bearings already. Any info would be greatly appreciated!
