So a friends J-D 2640 broke one of the ears off the steering bell crank. The ear that connects the fork with the long tie rod. He asked it I could replace teh bell crank. I checked out what it would entail and decided it would be easy enough. I secured a new bell crank and went over to do the repair. I removed the 3 ball joints from the broken casting without too much trouble. Removed the snap ring on the bell crank's pivot stud, only to find there is no where near enough room to remove the old part !!! There is a huge U shaped casting that connects the engine block to the front end pivot. The rear of the casting has a pivot stud with a snap ring, a washer and a couple of shims(which I removed), and on the front, a large pivot bolt/nut. Both pivots on that casting are horizontal and the bell crank stud is vertical. The tractor is equipt with a front end loader so I can use it to raise the front wheels off the ground, then block up the frame. It seems to me if I remove the front bolt and nut and remove the entire front axle assembly, thats still not gonna allow me to get that casting off or even allow it to drop down far enough to make the part swap. The rear pivot stud appears to be part of the casting? If it is, how did they ever put the part on to begin with. Can anyone shed some light on this for me? I'd like to finish this project up tomorrow.
