I wonder if anyone has a pic of exactly where the fuel line should run on my MH 20? When I got it the fuel line was off
and I replaced it and it seems to run until the bowls are empty and then dies. I know it is a gravity fed carb but the
sediment bowl and the carb are about the same level. So I don't know how the gravity thing is working. IM using the
origonal sediment bowl and I ran 1/4 inch piping to the carb. Also it will only run when the choke is on half? Any
ideas? I know the carb is in good shape because when it runs it runs well, It idles down nice and purrs. but then runs
out of fuel. One last thing. I also replaced the dist. cap and rotor when I bought it. It needed it BAD but the cap
doesn't really fit that well, it rattles and isn't held down very tight. can someone give me the part number to get
another one? Thanks in advance
