HanknotFrank
I recently asked about my 1953 Jubilee not going into gear when running. I probably should have explained it differently. It occurred to me that the only time it does it is after I start it up and run for a while. It has never not gone into gear at cold start up. It's always after running it for maybe 30 minutes or so. Also as a newbie, when we first inherited the tractor and finally fixed wiring to get it running, there were a few times that the tractor would all of a sudden just not go. That turned out to be the lever to the live PTO that I did not even know I had was being bumped by me when getting on and off the tractor. It is now bungeed in place. Could it be another newbie operator error causing my problem? Can the PTO engage lever cause gear shifting problems if it is not in the correct position? Thanks in advance.
