Got a imt 539 replaced head gasket torqued head to 60 ft lbs need to know how much to torque rocker shaft and what to set the valves on Any info will be greatly appreciated Thanks
Hello John welcome to YT! As you likely know you have
a bit of an oddball machine there. I will be surprised if
someone comes up with the info for you. Since our
host that provides this forum to us add free sells
manuals I rarely make direct references to any
competitors to them on the forums. I am making an
exception here because it looks like they do not offer a
manual for your machine. A bit of web searching got
me results for a down loadable manual for your
machine for a bit over $8. I have no experience with
them, but ETSY is the website that has it. Says it is a
veteran owned company, which when I checked it
appears to be correct. This is the best I can do for you
at this point. The search did show hard copy manuals
available in the $30 - $35 range, but in that case you
would be waiting for your printed info to arrive before
your project can be completed. Best of luck!
IMT work shop manual
(quoted from post at 08:41:13 10/25/23) Hello John welcome to YT! As you likely know you have
