Ford 6610 4WD power steering cylinder repair
rmshawgs
New User
Looking to remove and repair power steering cylinder on 6610 Ford diesel 4x4 . Anyone have any experience with this?
Yes. I did not remove, took tierods off both ends of rod, removed bolts and pulled rod and piston out. Have to turn wheels hard right or removing left wheel would make much easier. I did it with out taking the wheel off.
I believe that is what he is telling you. I have not personally done it but the reseal of different hydraulic cylinders from multiple applications with one end still connected to the machine has been discussed on here quite a few times. If it can be done and saves work and time I am all for it.
