Ford NAA 6 volt wiring
tholgate
New User
Hi all of you with loads of helpful information! I have a question regarding rewiring the rear work light. The original wire was cut, but unsure where it is connected on the light assy. I've searched for wiring diagrams and also looked in the parts manual, but they aren't all that clear. I'm sure it's a very simple answer, I'm just not confident around electrical issues. TIA[/img:c5f877e6a8]
Hello tholgate welcome to YT! Not a Ford guy so it
would take me a bit of research to answer your
question. I will just let a Ford guy handle that.
Hopefully one comes along, may end up moving your
post to the Ford forum section. I will give you a little
info on what needs to happen to get a photo to post
here. Pictures post through the ..Browse or Choose
files.. button just below where it says ..Upload
Photos/Videos.. down lower in the ..New post and reply
windows. I will add a screen shot of how it looks on my
phone. Clicking that will give you a choice to select the
file or folder the pictures are stored in on your PC or
phone. Then select the photo from the file and ..Add..
it. They cannot be pasted into the text area as a file.
(quoted from post at 14:08:09 10/12/23) Hi all of you with loads of helpful information! I have a question regarding rewiring the rear work light. The original wire was cut, but unsure where it is connected on the light assy. I've searched for wiring diagrams and also looked in the parts manual, but they aren't all that clear. I'm sure it's a very simple answer, I'm just not confident around electrical issues. TIA[/img:e92d79e427]
elieve reason no lights wiring info in manuals is that lights were not factory installed,but an add on. There were probably instructions in the kit, but that was almost 70 years ago.
