Dingo3
- Location
- Southern MD
I have a 2004 Foreman s and having difficulty starting.
First time It started right up and ran ok. After a brief shut off it would not start. Relay clicks but thats it. Thought it might be the starter going bad but did a jumper wire test as per manual and it turns freely. Relay is working ok also. My question is what is the minimum voltage needed to start the atv? My manual says 13-13.2 volts is full charge and 12.8 volts is 75% charge. When put on the charger it gets it to 13.24 but after sitting over night it drops to 12.92 Battery is about a year old. I also did a parasitic drain test and found nothing. Thanks for any ideas.
