Hi,
I'm trying to overhaul a Carter UT carburetor. It appears to be a 2612s and I was wondering if anyone was familiar with this carburetor? Specifically, I am puzzled about the high-speed needle assembly.
I removed the needle screw and its nut. Behind it was fibrous bushing. In the literature it is described as the main metering screw packing. What is this? It seems to be nearly worn away in my
carburetor. Is there any replacement or alternative for it? Also, is the metering jet behind it removable?
