Hello Tom welcome to YT! The number one problem is
that no M came from the factory with a solenoid. I will
link a diagram that shows a solenoid. The problem is
this one is set up so at any point the battery is
connected the starter button could be pushed and the
starter will crank. This is due to the left terminal of the
starter button being connected to the ammeter which
is always live. I would connect that wire to the terminal
on the ignition switch that power the ignition, the
resistor in this case. That way the engine will only
crank when the ignition is on, a semi-safety measure.
Looking closer I see what is probably your main
problem. By the arc spot on the small terminal on the
solenoid closest to us in the photo I trust that is where
you attempted to jump it. Sort of embarrassing but
follow the loop of that wire around and you will quickly
see what went wrong. The other terminal is the one to
jump to. That in my opinion is not the correct solenoid
for this application but it will work, providing that
powering that other terminal makes it crank.
Now secondly you did not reveal if the conversion
utilizes an alternator or generator. A photo panning out
a little and up on the distributor side of the engine
would show us what you have. If it is an alternator does
it only have one wire connecting to the large terminal
on the back or are there other wires that plug into it?
The diagram shows the wiring for the latter commonly
referred to as a three wire alternator. Just to square
everything up are you certain that the engine is free?
At the location you have it release the brakes and put it
in 5th gear, shifter to the right a down towards the
seat. Rock the rear tires back and forth with all the
force you have while watching the fan. If it moves all is
good, if not ..Houston we have a problem! I see it has a
Charlynn power steering setup, very good! My 48 has
one. You must have a unique pump mount on it it looks
like the mount sets in front of the governor and
extends down below the side channel frame to mount
the pump. FYI a make sure you take it out of gear
before you try to jump the solenoid. In 5th the starter
will not move the tractor with much force, but it will
certainly fail a test of your starer. We will see where
this gets you. Also if you send me an email I will reply
with a link for you to access some helpful
documentation to reference when repairing the factory
parts of your tractor.
Somewhat applicable wiring diagram
