Hunter1897
New User
1973 Ford 4500. Where can I find the ball bearing for the steering wheel shaft. I measured the ID (shaft diameter) to be 1.00". The outer diameter is harder to determine because the outer shaft housing has a small flange to assure the bearing doesn't pop out. But I measured that diameter to be about 1.835". So the real OD of the bearing is probably about 1.875". Photos of the steering shaft and the outer shaft housing provided. You'll see the inner race of the bearing still holding tightly to the steering wheel shaft and the outer race still inside the shaft housing.
This post was edited by Hunter1897 on 10/05/2023 at 08:22 am.
