HanknotFrank
Recently acquired Jubilee had been running pretty good after help from this forum for wiring and alternator problems.But now I can only change gears with the tractor not running. With it running it scraps and is very hard to get in or out of a gear. I read most of the posts on this site regarding a stuck clutch that is rusted. I assumed that was my problem but before doing anything I looked in my manual and it said to stop tractor before shifting gears which of course I do but I thought it meant to use low idle speed. Today I cranked it up and made sure I was at low idle speed when changing (and of course stopped) gears and it went into gear easily several times but later when tractor was warmed up the problem returned and I could not shift into gear. Thanks for any help.
