CASE VAC CYLINDER HEAD
Kenny Bill
New User
I have. a Case VAC 14. I am preparing to install the cylinder head. The parts drawing shows washers to be used pt. No. VT 4529. Can anyone tell me if
these are flat washers on lock washers?
Unable to find these machine washers. Do you know a vendor that would carry this particular washer. Do you have specifications on these washers
( OD. ID. THICKNESS. )
Try a grade 8 SAE flat washer. SAE washers are generally a smaller ID and OD and than the USS ones.
Strange, the G49404 washer shows up used in a lot of newer equipment. If they discontinued that number, I would have expected they would have substituted a different one, just like the G49404 washer was substituted for the VT 4529 washer.
