case 220 not charging
gejurkovich
New User
checked stator for continuity, good
stator out put seems to be only 3 volts ac
output from rectifier seems to be only 1 volt dc
if I'm doing it right. next thing i guess is to check both stator leads for grounding out to frame.
any thing else ?? TIA
(quoted from post at 12:34:52 09/08/23) checked stator for continuity, good
Welcome to the forums.
You might want to try posting about your Case 220 in the Garden Tractors Forum on this site. It is further down the index list. Here is a link you can click to go to it.
https://forums.yesterdaystractors.com/viewforum.php?f=28
