jim_lawless
New User
I have a Massey Fergusson 40 tractor, mid 1970's, with the semi-automatic quick reverse mechanism - hence separate forward and reverse pedals. Initially it worked fine, but after a while would only go in reverse and now won't move forward or back using the foot pedals. I found that the external linkages from the foot pedals to the side of the torque convertor housing were worn, to the point that the lever at the top which actuates the hydraulic valves (I guess) does not move far enough to engage. I tried taking the slop out of the linkages (using fishing line!) but it still won't engage. But if I move the aforementioned lever far enough by hand it does engage. so there is not a problem with the torque converter itself. Any clues? Could it be there is a part missing? I am considering fitting a hand opening rod to the lever mentioned, but that is not a very safe option when operating on hills. Am I missing something?
