Hello, Ferguson TO20 owners. I've installed the 12 volt conversion kit and the pertronix ignition kit from Yesterday's Tractor. The kit contained a new wiring harness and diagram so all the old wiring was pulled out and the new installed. My problem is that when wired as instructed, the tractor will not turn off when you turn off the ignition key. It starts and runs beautifully and really makes me smile until I tried to turn it off. I turned off the gas in order to stop it. I triple checked the wiring and it is exactly what the diagram indicates. Any ideas?? I did the same conversion to my Ford 9N last year and it is still working perfectly. Thanks in advance
