Prairieviewacres
New User
Looking for help on getting the power steering working again in my Case 1070. I used the tractor all summer to cut hay and then at the end of the season it started to leak really good at the power steering pump under the dash. Took it out replaced some rubber gaskets and reinstalled it. Now it needs lots of muscle to turn the wheels and they only turn a little bit then stop. I have ensured that all the air is bled out of lines, confirmed the pump is getting lots of oil and even confirmed the pump is pumping out oil. I have had the lines disconnected to ensure oil was coming and out where it should, made a big mess but didn't know how else to confirm otherwise. Looking for help determining where to investigate next. If you need pictures or videos of anything let me know.
