ViperTrails
New User
Other than a cracked block/head or head gasket leak between oil and water ports which did not impact the cylinders, what else might cause milky oil on a 1952 8N with normal spark plugs and 90psi compression on all 4 cylinders?
I have read that if the intake manifold was drawing water through the mounting studs that the spark plugs would appear pressure washed not normal carbon covered.
The pressure test was performed with the coolant drained.
Suddenly after 10 minute idle, the radiator was low and the oil stick was too high.
This post was edited by ViperTrails on 08/26/2023 at 11:49 pm.
