Currently using a 9N to do mule work around our hunting grounds (Northern Michigan), changed the oil over the weekend (10W-30) and thought there may be a starting issue. We tried pull starting to no avail, but then put the battery up on a charger and it fired up.
After about 5 mins started hearing a knocking sound in the front of the engine, but there wasnt a rhythm to it. Then noticed there was coolant leaking from the front of the fan. Im assuming my water pump is bad, but would that also explain the knocking in the front of the engine? It sounds like the knocking is coming from where the fan is but its hard to determine.
