Madmartigan
New User
Hey gang
New member here, sorry if this has been asked before, but I have a Freguson TO30. I bought it knowing there was low oil pressure. Everything seem to run fine besides the oil pressure. I drain the oil and notice milky grey oil and some antifreeze. Check the oil pump which seems to be working fine. Sit on this for a little while. Order new gaskets. Im ready to start back up with this project. I pull the oil pan back off and there s a good amount of antifreeze. I did not put oil back in it and obviously hasn t been started. I need help trying to figure out how deep this problem is.
Thank you
Joshua
Thank you
Joshua
