MF35 psi with water ballast
spelman35
New User
We bought new 13.6x28 tires and rims for our tractor. We've filled them 75% with water ballast, what should the psi be? It measures 28 psi, is this correct?
Thank you!
Shawn
Ballast in the tires does not change the recommended air pressure. 28 psi is way too much. A MF 135 with 13.6 x 28 tires recommends 14 to 16 psi. What pressure did you run in your old tires? What does your operator's manual recommend for a pressure? Depending on implements or other weight you may carry on the 3-point hitch you might add a couple pounds to the recommended pressure. You might go a couple pounds less, if the tires aren't flattening to the ground on the bottom.
