farmall H tractor
Hello TGR welcome to YT! Not sure how old you are
but surely by now you have figured out we do not live
in a perfect world. What should happen and what does
happen is often two different things. You dont give us
any details about the previous life of this tractor. If
someone stuck a 12 V battery in it and turned on all the
lights, poof.. all the bulbs just burnt out. And then
theres bad wiring, bad switch and yes it has a fuse.
The fuse is on the light switch in the little oval box with
the ammeter on it. I am attaching a link to a previous
post with wiring diagram for an a battery powered
ignition. That means it had a distributor with points
and a coil, and note that is not the same as a magneto.
We will see where this takes you, do you have an
automotive test light? If not you need to get one.
Previous YT post with wiring diagram.
