Ford 3600 BushHog / lift arms won t go down
Hi All, seems I have a hydraulic issue and I m not sure how to start diagnosing the issue because the BushHog is still attached and up in the air. I m guessing there s a pressure buildup that won t allow it to go down. Any ideas on how to carefully get the bush hog down so I can do repairs without it dropping down uncontrollably? The hydraulic fluid is milky, I took the filter off to see if would relieve some pressure but it didn t. I don t see a pressure relief valve anywhere.
