I have a To-35 that I have gotten to start again after professionally getting the gas tank cleaned, new fuel bowl, rebuilt carb, cleaned/new air oil cleaner, new coolant and getting ready to change the oil next. I replaced the battery which was 12v so I replaced it with the same v. battery. After about 15 minutes of idling the tractor will start to stumble and die even if I pull the choke it will die. I would have to wait a couple hours or the next day and it will run like new. This happened even before the rebuild..(i thought maybe the tank was causing it to die so that why i rebuilt it) The carb is getting enough fuel, I pulled the drain nut and it is running normally. My question is, how do I know if my tractor is a 6v or 12v? Im guessing the coil is getting to hot and its not working probably but how do I know for sure?
Also, if its the wrong battery should I change the coil and condenser and get a 6v battery? Or will just a new 6v battery help it not die after 15 minutes of running?
This is my great grandpas tractor that my dad used to drive daily.. Im hoping to get it fixed by Christmas for him.
