The tractor sat all winter because the carb was leaking. It looked like it was leaking where it connects to the air intake(rubber boot). I don't have a shop so I waited until spring to fix it. I just rebuilt the carb yesterday. Also replaced the sediment bowl and fuel tank as well. It has an inline fuel filter (new) just before the carb. The rebuild kit had literally everything in it and I also put in a new float, which i adjusted to 1/4 inch, so all the internals are new. The only thing that wasn't replaced was the air horn packing. I was trying to tune the carb yesterday but it wasn't working and it felt like the engine had about 1/2 the power it used to. I went out today to try again and saw it was leaking again. There are drips from the air horn drain, the drain bolt, and the rubber boot from the air intake. The top and bottom halves of the carb look wet. About an 1/8th inch on both sides of the seam . It seems like gas is coming out of everywhere. I've looked at my shop manual but I'm at a loss. Does anyone have any idea what the deal is with this? Also the fuel line looks wet because I took it off just before I took the pictures. Any help would be greatly appreciated.
