Hello Gang,
The clicking solenoid issue i was having was resolved by replacing the neutral safety switch! The tractor started but it is blowing inline fuses.I have a 30 amp fuse inline, with 10 gauge wire. I'm wondering if the push button, key switch and neutral safety switch wiring job is my problem.
This is how I have it wired:
1. key switch (I)terminal to starter button
2. starter button to neutral switch
3. neutral switch to small post on solenoid.
I also have the coil wire and volt meter connected to the key switch(I) terminal.
What does it mean when the fuses blow?
Thank you!
Shawn and Ole Red
Thank you!
Shawn and Ole Red
