Keith Molden
My 6'rotary cutter, I have no idea what brand, has 27 1/ long by 4 wide blades on it. I can't seem to locate any that are 4wide and they are about 1/2 thick (don't remember the thickness for sure) has one blade bent down to the point where it hits the ground. Question is can I put it in my press and straighten it? I don't think I'll have to apply heat with a 50 ton press but I might. It's bent at the 2nd bend from the mounting point. Wondering if it would be ok to give it a try. I usually don't mow brush only some briars and tall weeds. Thanks for your thoughts in advance, Keith
