Hi all,
Some advice please. I got a Mitsubishi MT372d tractor with 350 hours on the clock and it makes a grinding noise whenever I release the clutch out but NOT when I pull the clutch in or hold it there. I googled symptoms of a bad release bearing and it said it makes a noise whenever the clutch pedal is pushed in or held there. But mine doesn't do that. It just makes that noise when the clutch pedal is released out. So I am asking if anyone knows what my problem could be?
Also, is 350 hours on the clock too low for a release bearing to go bad?
Sfath
Sfath
