Ive got a ford 801 with the 172 gas engine. When Im
plowing the field and put the tractor under a good load it
does fine for a few passes but then it soon starts to sputter
and stalll. If you let it cool off for a minute it will run fine
again but after a few minutes of plowing it goes right back
to sputtering. Ive already replaced the spark plugs, plug
wires,condenser, points, rotor, and the cap. Just yesterday I
put a new 12v coil that is internally resisted on from tractor
supply and it seemed to almost cure the problem but on the
drive home it started to sputter going up a hill in 10th gear.
Could this be a crappy coil from tractor supply or another
issue? Also Ive rebuilt the carb, fuel lines and the bottom
drain in the tank has been replaced. Any advice?
