I have a late model B that I need the clutch pulley repaired. The hole in the operating sleeve that fits over the drive pin is wallowed out to the point I can't adjust the clutch any more. I need someone who
can remove that operating sleeve and weld the hole back into spec to fit the drive pin without and side to side play. I live in upstate NY, so anyone within 100 miles of Binghamton would be great. Also if you
know of a salvage yard that has late model B's , that info would help also since I would consider buying the whole clutch pulley assembly if it had a good operating sleeve.
