I have a 73 Ford 3000 gas burner. The governor is not
functioning properly. When the throttle is moved to either low
or high idle, it will not move the governor rod or throttle on the
carb. I removed the rod as outlined in the IT manual and it is
the correct length. If I hold tension on the governor rod at carb
it will move, but without tension nothing happens. Anyone
dealt with this or have a solution?
