AgroRepairApprentice
New User
So my uncle run a tractor repair service for 30+ years, I have helped him split several hundred tractors and they go back together with no trouble, with exception of this Case tractor.
We can get literally 1 inch from this tractor being back together,
We are even using a spline allingment tool to make sure everythng is in place before moving it back together.
Now, there is a Clutch plate that goes up agianst the flywheel, Next is the disc with notches for each bolt that holds it in place followed by a scondary un notched disc that goes flat when the bolts are tightend and a spring approx 2 1/2 inches long that goes in the hole where the shaft that goes back to the PTO inserts into the engine of the tractor. Everything is allinged properly we get 1 inch from being together and no amount of manually spinning the fly wheel or the PTO does any good. We dont want to force it together with the bolts and break something. been trying for 3 days to no avail any input would be helpful. Please and thank you!
